3 - Electrical
Sub Forums:
Threads
- It's raining - no start! 21 Oct - aarrggh (4 Replies)
- Car started then stalled, wouldn't restart (3 Replies)
- Binacle lights not working, hot rheostat (12 Replies)
- ignition barrel problem (1 Reply)
- Instrument cluster 16pin plug/connector replacement? (0 Replies)
- Speedo going a little crazy (9 Replies)
- Hella vs Valeo (17 Replies)
- Window motor fitting hell (9 Replies)
- No interoir lights (5 Replies)
- Craig radio - alternative options (2 Replies)
- Rev counter duff, talk of replacing a processor? (2 Replies)
- Fitting seperate rear fog light. Need spare switches as well (17 Replies)
- What's going on here then?............ Relays and Loom (3 Replies)
- Seatbelt dash alarm (23 Replies)
- Relays - Worth replacing? (3 Replies)
- LED's v's incandescents for rear light clusters (6 Replies)
- Licence plate LED replacement (2 Replies)
- LED'S for amber side marker/indicator (after mod) (3 Replies)
- Door marker LED replacements (0 Replies)
- Car back from auto electricians, few small issues/questions. (4 Replies)
- Can't start, won't start, shorting issue... (4 Replies)
- Mirror switch wiring connections (1 Reply)
- Door light switch question (5 Replies)
- Fuel pump not running, but it works when relay is jumped (27 Replies)
- New owner of Vin 4468, with a few teething problems! (9 Replies)
- Mirror Switch Crossover (1 Reply)
- Temperature Gauge + Sensor, please help! (31 Replies)
- Dash lights not working (3 Replies)
- Alternator. (0 Replies)
- low voltage on startup, then fine after 20-30 seconds (11 Replies)
- Roof Mounted Aerial (4 Replies)
- Speedometer reading 35mph at 70mph?? (7 Replies)
- Side post batteries for sale on eBay (1 Reply)
- Windshield Washer (1 Reply)
- multiple instrument cluster issues (11 Replies)
- DeLorean Battery drain (7 Replies)
- Annoying Horn Problem (19 Replies)
- Front Speakers - Replacements (5 Replies)
- RPM Gauge (0 Replies)
- Passenger Side Sidelights Not Functioning (7 Replies)
- Original battery with side connections... (3 Replies)
- Electric rear radio aerial (0 Replies)
- Craig Radio - Tape Jammed (0 Replies)
- OEM-spec inner main beam headlights (5 Replies)
- Indicator bulb (1 Reply)
- Idle speed altering when fans cut in (10 Replies)
- fluorescent clock on its way out (7 Replies)
- Engine Compartment courtesy light (2 Replies)
- Washer bottle canopy fasteners (7 Replies)
- Are these the right lights for the UK? (0 Replies)
