13 Apr 2013, 17:56
For every thing I fix, something else gets broken -_-
Got the tape out my radio by removing the center console and dismantling the tape deck. Putting back in the radio and I accidentally knocked the headlight switch connector out. Upon plugging it back in, I know have a really bizarre issue;
I have the original physical switch, but according to documentation that came with the car the connector has been upgraded to avoid the overheating issue.
Based on the symptoms I believe the bulbs are good and I must have somehow shorted/broken a connection? Any obvious places to start or wiring diagrams I can use to aid in my searches with a multimeter?
As a side note, when using the remote keyless entry it flashes the sidelights, and only the drivers side illuminates then too.
- When using sidelights, only the Drivers Side illuminates (both headlamp and indicators)
- When using dipped beams, both sides illuminate
- When using full beams, both sides illuminate
- When using indicators on any setting, both sides work as expected (same with hazards)
- On all settings the actual button on the center console does not light up at all
