21 Nov 2014, 14:28
Hello,
This is a interesting one; electrical which is always confusing!
The headlamp switch classically burnt out, partially melting the black wire which is paired to the headlamp's blue wire disappearing off to the "Acc" on the foglight switch.
I struggled home in the dark using main beam only! Allegedly... :-)
I took off the centre console & another black wire, from the foglight switch's "ground", also had to be replaced due melting. This was paired into the clock's black wire...
Even before I installed the new LED based headlamp switch, I noticed that I couldn't turn the starter motor or flash the headlights without an almighty drop in voltage and the console lights dimming, with voltage showing no more than 8v...
Turning off then on again the main battery isolator resets everything to about 12v, bright lights, but no further!
Most things, like the foglight switch are disconnected for trouble shooting, but still no clue...
Perhaps the damage goes further than I can see and is causing a short somewhere?
(Wiggly AMPS! Curse them when they're not going in the correct direction!)
Anyone any suggestions?
Mat
Frenchy 3866
Mat
Frenchy 3866
