Welllllllllll,
<begin technical waffle that makes me sound clever>
There is an argument for replacement, based on three things:
Relaxation - contacts losing their 'springyness' over time, resulting in a weaker contact.
Fretting corrosion - contact wear caused by tiny vibrations.
Contact erosion - sparks causing the contacts to be gradually eaten away.
This 'wear' is caused by
use not
age
Generally relays are rated at in excess of 250,000 close/open cycles
<end technical waffle>
Some owners will replace them because somehow they feel they ought to, in order to 'prevent' some failure that is unlikely to happen. In reality if anything is going to cause you problems, it will be the relay sockets themselves.
Given the amount of use your DeLorean has had, almost certainly less than 100,000 miles, the likelihood of the relays actually
needing replacement is virtually nil.
From personal experience I've had my DeLorean over 11 years now (my God has it been that long) and it still has the original relays in it. I go by the old saying: if it ain't broke.....
Of course if you don't replace them and one fails, then you'll wish you had. But then you can use that silly argument for every single component on the car.....
As per the first post on this thread,
Quote:Dipped Beam, Main Beam, Fan 3rd Speed, Fan 4th Speed, Cooling Fan Start Inhibit, AC Ilumination
are interchangeable, so if one did fail, you can always swap it over for another if you're in a fix.
The decision is yours.....
