4 - Transmission - Manual & Automatic
Sub Forums:
Pages: 1 2
Threads
- What is a fair price for a working auto trans governor? (1 Reply)
- Automatic Governor (6 Replies)
- Autobox throwback/jump (6 Replies)
- Autobox rebuild/replacement (15 Replies)
- Auto box oil change and kickdown switch (7 Replies)
- Daft Question..? Gearbox =/ Diff? (6 Replies)
- Auto box filter change? (7 Replies)
- Auto Gearbox wanted (17 Replies)
- How does the PNDR work from the shift cable (1 Reply)
- Drive shaft removal (14 Replies)
- Clutch Slave Cylinder (22 Replies)
- Driveshaft to differential oil seals (8 Replies)
- 104002 END FITTNG G/SHIFT (0 Replies)
- Clutch replacement (48 Replies)
- 4th gear won't engage (22 Replies)
- Clutch master cylinder - resleeving worth it? (15 Replies)
- Manual Gearbox oil, recommendations? (8 Replies)
- Clutch issue (2 Replies)
- Clutch reservior access panel questions (4 Replies)
- Clutch Master Seal Kit (12 Replies)
- How to remove manual gear knob? (3 Replies)
- Rear Glass Replacement (1 Reply)
- Clutch Slave Cylinder (11 Replies)
- Automatic Transmission Filters ++ Prices and pre order info (5 Replies)
- Clutch, fork and screws (17 Replies)
- No drive to drivers rear! (18 Replies)
- Squeaky Clutch and Gear Level not returning to Center (8 Replies)
- Transmission Oil Plugs - Sealing washer? (4 Replies)
- CV joint query (2 Replies)
- Compression sleeves? (2 Replies)
- UN1 advice? (6 Replies)
- Pilot bearing- 2RS? (1 Reply)
- Drive Shaft Roll/Flange Pin (4 Replies)
- Two Gear box Oil Leaks (42 Replies)
- Brake/Clutch fluid flush through replacement (7 Replies)
- first gear selection problem (7 Replies)
- Clutch fork clip position (1 Reply)
- Gear shift issues (with photos) (9 Replies)
- Input shaft seal needed (3 Replies)
- 10 spline clutch part number (5 Replies)
- Driveshaft locking pin removal punches (1 Reply)
- TROUBLE GETING IN 2ND GEAR !???!! (16 Replies)
- Master clutch cylinders (1 Reply)
- Replacing drive shafts (3 Replies)
- Leaking Driveshaft seals - After fitting speedi sleeves help (0 Replies)
- Removing Gearbox (4 Replies)
- Drive Shaft Differential taper bearings (3 Replies)
- drive shaft rebuilds. (7 Replies)
- UN1 Gearbox (1 Reply)
- Automatic Transmission Fluid Leak (2 Replies)
Pages: 1 2
