05 Mar 2014, 00:04
As I have the box out just now, I'm doing what needs done while its on the floor.
The selector shaft has always had a slight weep, and the rubber bellows have definitely seen better days.
To replace to seal on the shift selector shaft, I take it I have to remove the end casing from the box.
Can anyone tell me of any problems with removing that cover? Nothing is going to leap out is it? Or necessitate any further work?
From the diagrams, will I need to replace 2x roll pins to reassemble?
Other than this seal (and of course the paper gasket), is there anything else to replace when that casing is off? I take it the notorious 2nd gear roll pin requires splitting the 2 case halfs?? I am simply not doing that, but I do want to get rid of the little drip from the shift shaft while the box is out.
andy
andy
