2 - Emission / Fuel Systems
Sub Forums:
Important Threads
- STAINLESS EXHAUST DECEMBER SPECIAL (70 Replies)
Threads
- Replacing 13 lines inc fuel Filter (5 Replies)
- Frequency valve removal (2 Replies)
- Dwell testing (0 Replies)
- Weird Binary Fuel Pump Starting issue..? (7 Replies)
- Fuel odour in the cabin (8 Replies)
- K Jet Metering Head Re-Build service (0 Replies)
- hesitation/popping of the engine at higher RPMs (1 Reply)
- Fueling Issues - Looking for opinions on PPR (24 Replies)
- Fuel pump replacement kit (14 Replies)
- More stuttering under load -suspect fuel pump (11 Replies)
- Stuttering when accelerating under load (7 Replies)
- Hot Start Problem (9 Replies)
- Changing fuel filter leaky woes (21 Replies)
- Stainless Exhaust (1 Reply)
- New Exhaust Muffler (5 Replies)
- PRV V6 Engine Purchase (2 Replies)
- Fuel leaking from tank when filled?? (12 Replies)
- Fuel injection system problems (7 Replies)
- Fuel pump x-ref? (7 Replies)
- Emmissions high and stalling at lights (6 Replies)
- Replacing a cracked/split injecter hose (9 Replies)
- Is there any venting on the fuel tank? (2 Replies)
- Hot start issue (3 Replies)
- Fuel pick up baffle and filter problem (1 Reply)
- Non starting issue, fuel pump not priming a cause? (10 Replies)
- Best place to get a replacement CPR / WUR (6 Replies)
- C.P.R (11 Replies)
- Its brassing me off! (14 Replies)
- Special T Fuel Sender Unit (14 Replies)
- Fuel distributor ports - what does this one do? (3 Replies)
- Fuel sender (5 Replies)
- Determined to rectify this low fuel spluttering..... (17 Replies)
- Non starting issues... Have I disturbed something? (10 Replies)
- Fuel leak to accumulator (9 Replies)
- Engine not correctly returning to idle (6 Replies)
- K Jet Debugging guide (0 Replies)
- HOT WARM START ISSUE - NOT ACC (4 Replies)
- Stainless Steel Exhaust System - sold out - (2 Replies)
- Fuel pump on it's way out? (22 Replies)
- fuel pump banjo bolt size? fuel line size? (3 Replies)
- fuel tank packing pads? (3 Replies)
- Fuel leak at top of pump (9 Replies)
- 2.7 or 2.8 fuel metering unit? (9 Replies)
- PROBLEM STARTING WHEN WARM (3 Replies)
- Leaking fuel line :( (12 Replies)
- DOC Stainless Steel Exhaust *Spring Special* (8 Replies)
- Original vs. updated fuel pump? (2 Replies)
- Rough running (6 Replies)
- Idle mixture adjustment (3 Replies)
- another starting problem (8 Replies)
