Full Version: fuel pump banjo bolt size? fuel line size?
so im just sorting the missing bits from the delorean, and wondered if anyone off top of their head knows the size of the banjo bolt that goes on the fuel pump? (106976)
also while i am at it what size is the rubber fuel feed/return line? (106979) car is not to hand at the minute so can not check myself
many thanks again!
If your pump has a banjo bolt it'll be an M12 x 1.5mm. if you're replacing the pump, you'll get one that needs a domed nut of the same thread,.
yeah it was a new replacement pump with banjo fitment, cheers for that
Type "bosch fuel pump nut" into google, you'll soon find one. it's a non-standard dome nut, annoyingly.
