03 Oct 2010, 13:44
Had to adjust my idle mixture as the car was ticking over roughly, and rembered that at the Tatton Park show Phil said that a 3mm Allen key would fit the adjustment screw in the injection unit, so going by the Volvo manual I had to give 3/4 of a turn clockwise to bring it back to a really decent tickover, and readjusted the throttle screws to give a happy 850 rpm idle. Didnt have a co analyser to hand so will have to check the emissions shortly, big difference on fuel consumption, more mpg! The Volvo manual says adjustment is done with an instrument screwdriver, I tried this but on close inspection the screwdriver just spins inside the allen key giving no effect on the mixture at all. Try adjusting the mixture yourself if performance is down, but make sure all the ignition system and fuel supply etc are in good order. 8)
I would check your CO levels - that's a serious amount of richening!
