13 Oct 2014, 17:32
Hi! I sent my engine over to a local company who rebuilds engines. They gave me a list of what parts I need:
Gasket kit (already have this)
New Pistons (With Liners, Rings, shims)
Main bearings
Rod Bearings
Camshafts
Valve Lifters
Valve Springs
Timing Chain Kit
and perhaps a New oil pump.
Any thoughts on this? Do i need something more?
Ive heard that you should not mill the valvehead surface on these engines, correct?
And, I could not find the timingchain in the parts list at delorean motor Company, just the guides and fastners. Where to find this?
Should I change the gears as well? or are these usually good?
Was thinking about buying fast camshafts and High compression pistons from Delorean Europe, but these pistons do not include the liners. Any where I can get them seperate?
Do I need better headgaskets With these? (I have no trouble dropping the Hi compression pistons)
Main bearings
Rod Bearings
Camshafts
Valve Lifters
Valve Springs
Timing Chain Kit
1981 DMC Delorean VIN 1598
2004 Peugeot Partner
x1979 Pontiac Trans Am
x1975 Chevrolet El Camino
x2002 VW Multivan
x2001 Peugeot Partner
x2007 Peugeot 307
x1995 Fiat Punto S55
x1966 Lincoln Continental
x1974 Plymouth Satellite Sebring
x1982 Porsche 944
x1988 Audi 100 2.0E
x1986 VW Jetta GL
x1982 Audi 80
x2002 VW Multivan
x2007 Peugeot 307
x1982 Porsche 944
x1988 Audi 100 2.0E
x1986 VW Jetta GL
x1982 Audi 80
