13 Oct 2014, 17:32
Hi! I sent my engine over to a local company who rebuilds engines. They gave me a list of what parts I need:
Gasket kit (already have this)
New Pistons (With Liners, Rings, shims)
Main bearings
Rod Bearings
Camshafts
Valve Lifters
Valve Springs
Timing Chain Kit
and perhaps a New oil pump.
Any thoughts on this? Do i need something more?
Ive heard that you should not mill the valvehead surface on these engines, correct?
And, I could not find the timingchain in the parts list at delorean motor Company, just the guides and fastners. Where to find this?
Should I change the gears as well? or are these usually good?
Was thinking about buying fast camshafts and High compression pistons from Delorean Europe, but these pistons do not include the liners. Any where I can get them seperate?
Do I need better headgaskets With these? (I have no trouble dropping the Hi compression pistons)
Main bearings
Rod Bearings
Camshafts
Valve Lifters
Valve Springs
Timing Chain Kit
