Firewall
Can anyone suggest a remedy, for some reason only in the last few days the DOC site on my computer will not show unless I dissable the firewall from my MCAfee software, any ideas welcome as it is a bit of a pain having to disable each time, thanks Stephen.
VIN LESS at present
DOC 670
Can you add an exception to the software?
There's nothing on the website which should cause a firewall issue AFAIK
Cheers Rich, that has done the trick, don't know what brought that about but done an exception and we are up and running.
VIN LESS at present
DOC 670
I had the same problem. There was a 'potentially unsafe' website warning attached. Whatever happened has been corrected, the site now loads normally without needing the exception.
John C
