Can anyone suggest a remedy, for some reason only in the last few days the DOC site on my computer will not show unless I dissable the firewall from my MCAfee software, any ideas welcome as it is a bit of a pain having to disable each time, thanks Stephen.
Can you add an exception to the software?
There's nothing on the website which should cause a firewall issue AFAIK
Cheers Rich, that has done the trick, don't know what brought that about but done an exception and we are up and running.
I had the same problem. There was a 'potentially unsafe' website warning attached. Whatever happened has been corrected, the site now loads normally without needing the exception.
John C
