Threads: 79
Hi
to cut a long story short: I knackered mine. :oops:
Does anyone have a spare driver's side steering rack bracket they'd sell to me? it's the rounder one of the two.
cheers me dears.
Dave.
- Dave Smith
VIN: #00944 DOC: #535
VIN: #03193
Threads: 813
I had the same problem when I removed mine, the threads were bust. Unfortunatly DMCH have run out of these, (they have plenty of the others :roll: ) I did get a secondhand one but the thread snapped on this also. In the end I cut off the round threaded part (like an exhaust clamp) and welded on some bolts with the head cut off.
Threads: 79
cheers Chris.
I was thinking of cutting off the round bar and replacing it with some screw thread.
I made the mistake of not using a HT steel nut when re-installing mine - it didn't take a lost for the thing to cross thread and couldn't get the thing off without cutting through it with my mini cutting tool (unfortunatly I'd knackered the thread.)
ta
Dave.
- Dave Smith
VIN: #03193
Threads: 79
what's this thing plated in? kind of goldie/copper colour?
- Dave Smith
VIN: #03193
Threads: 43
Hi Barson,
If it's like many of the other plated components on the car, it'll be zinc I think.
Phil
Threads: 79
yeah - i thought that, but on the underside it looks shiny goldie colour. Doesn't galvenising with zinc produce a flat grey colour?
ho hum :oops:
- Dave Smith
VIN: #03193
Threads: 813
Barson Wrote:cheers Chris.
ta
Dave.
Be carefull using threaded rod, from my limited usage with it, it is a fairly soft metal, and easy to strip the threads (again) :oops:
Silver plating is zing, gold plating is (or was) cadmium. These days it's yellow chromate (sp?) but that's being banned too apparently.
I have a couple of sets of rack brackets.
Threads: 79
ahh - cadmium.
can you sell me one bracket? :oops: or do i need the pair? :?
- Dave Smith
VIN: #03193
Threads: 79
or i should say, do i have to buy the pair?
- Dave Smith
VIN: #03193
Threads: 43
This is taken from the Millennium Concours group and was posted by Dave Swingle to show the difference between cadmium plating and OEM-style yellow zinc plating:
The caption for the photo reads "Darker one is Cadmium, Yellow Zinc is proper"
I don't think yellow zinc existed in the early 80's... I thought it was developed as a replacement for Cd when that became illegal... dunno for sure.
No, I won't make you buy the pair
