sidelights wired wrong?
No its just held on with 4 'clips' , be prepared to find allsorts behind there thou Smile
:lol:
anyway. no, it just pulls off get your hands at both sides and give it a hard yank and it should come right off. (that's assuming that you're inner headlights are off)
are ther no loose connections behind the headlights that you can see (maybe once upon a time they were hooked up)?
no loose connections at all, im guessing it was undone at some point. if there is no other wires behind the panel then which wires should i be looking at from the back of the yellow ones and how do i get behind them? If this is needed i can just wire it up so the yellows and whites are on at the same time.. i think, lol
DOC 527
Vin #10264
