30 Jun 2018, 20:17
Thought I’d start a new thread on this, just in case it’s of help to anyone in the future....
In my case, the temp gauge always stayed pinned at 100f.
The usual grounding check did nothing to the gauge when ignition was on, despite installing a new temp sender, and cleaning all connections on the bulk head.
(If you’re reading this for help, do the above first)
So, next I checked continuity between the connector on the temp sender and the connector on the bulk head, and this was fine.
(It’s the white connector nearest to the firewall under the yellow one, 3rd pin opening up on the right of the connector - or simply trace the wire colour to the pin)
Next, I checked continuity from the engine bay all the way to the binnacle. I didn’t want to remove the binnacle yet - so I performed some “on the back tests” in the footwell, seeing as all 3 connection bolts for the gauge are accessible when looking up.
With the ignition on, I checked for power on the bottom bolt (ground) and the right middle bolt (live).
Thankfully for me, there was 12v.
This means there’s a continuity issue between the bulkhead and the gauge.
So next I ran a long cable from the engine bay connector into the car and used that to check continuity with my multimeter to the back of the gauge.
(The sender signal bolt is the left middle bolt)
I had ZERO continuity on the bolt itself, BUT I did have good continuity on the circuit board under the nut that connects the circuit to the bolt.....
AH HA!!!!! Thankfully continuity is intact from the engine bay, from the bulk head, to the binnacle connector and the circuit board.
Now - this is were the solution is to remove the binnacle and replace the nut with a nice brass one to get a proper connection.
Whilst this IS what I will be doing - I want to get out and enjoy the car and do this over the winter.....
So I cheated..... I ran a brand new wire from the back of the gauge, through the bulk head and on to the temp sender......
Hey presto, TEMPERATURE GAUGE IS WORKING!!!!!
Wooo hoooooo!!!!
Wooo hoooooo!!!!
