3 - Electrical
Sub Forums:
Threads
- cross references for relays (3 Replies)
- Delorean won't start (46 Replies)
- Bracket under dash (3 Replies)
- Fitting Hellas (19 Replies)
- Directional indicator on cluster not working.... (2 Replies)
- Speedometer strangeness (2 Replies)
- New battery but now no power! (12 Replies)
- Tachometer not working. Steps to diagnose? (3 Replies)
- Temperature gauge not working - NOW FIXED (6 Replies)
- 102684 Vacuum advance unit (0 Replies)
- Incorrect headlight wiring & melted fuse (5 Replies)
- Radio and cassette static.... (5 Replies)
- What is this ground cable for?? (3 Replies)
- Temp gauge - is this the sender?? (13 Replies)
- H4 headlight bulb recommendations? (2 Replies)
- Rectifier diodes for fog light conversion (13 Replies)
- Ducellier Alternator (8 Replies)
- Window Regulator issues - any ideas? (7 Replies)
- Fuel gauge is pointing down no matter what (9 Replies)
- Craig Radio repair (8 Replies)
- Craig aux port - anyone tried? (3 Replies)
- Distributor cap orientation? (3 Replies)
- Distributor cap clip screws? (0 Replies)
- Rotor arm definitely needs a change! (2 Replies)
- Window washer motor (4 Replies)
- Inertia Switch bypassed, should I replace (4 Replies)
- No power to starter (2 Replies)
- Possible ground short??? (3 Replies)
- ASI Radio PCB and potentiometer (0 Replies)
- Interior light diodes (1 Reply)
- Alternator - Modern Cross Reference (9 Replies)
- Full Throttle Microswitch (1 Reply)
- Ignition switch-cheap replacement! (4 Replies)
- Plug Lead (14 Replies)
- Dipped headlights deciding not to work! (2 Replies)
- Adding a high level brake light (5 Replies)
- LED friendly Flasher Relay and Capacitor (6 Replies)
- Mode switch - 'heater' - no. 10 fuse blows (3 Replies)
- It's raining - no start! 21 Oct - aarrggh (4 Replies)
- Car started then stalled, wouldn't restart (3 Replies)
- Binacle lights not working, hot rheostat (12 Replies)
- ignition barrel problem (1 Reply)
- Instrument cluster 16pin plug/connector replacement? (0 Replies)
- Speedo going a little crazy (9 Replies)
- Hella vs Valeo (17 Replies)
- Window motor fitting hell (9 Replies)
- No interoir lights (5 Replies)
- Craig radio - alternative options (2 Replies)
- Rev counter duff, talk of replacing a processor? (2 Replies)
- Fitting seperate rear fog light. Need spare switches as well (17 Replies)
