Threads: 4
Since purchasing this it has been a challenging project. I have had the roof/door linings recovered. Started to replace all the seals for the doors, the ones near the torsion bar are going to be a bit testy. Fixed the windscreen washer and horn. Replaced the headlight switch and the window switches. Repaired the seat adjuster, fitted new seat belts and rear speakers. Replaced the exhaust pipe that is usually where the cat converter is located.
What have you all done about replacing the Cibie headlights in your Deloreans, I realise they are not made any more and I have one cracked High/low beam and one cracked low beam lense.
I have not even started on the engine, hopefully just a clean up and a service will do as it seems to run quite well. maybe new belts, oil, plugs. Seems like he list just goes on and on.
The next purchase is a 2 post hoist to get this bad boy off the ground and up in the air. Luckily I live on a 2 1/2 acre property and have 2 6x4m sheds all with power.
Sound pretty much par for the course to me. Your a very lucky boy to have such a nice new toy.
I got mine today as well AXI 1698. First challenge is the brakes!
Use the proper stuff this time Chris
http://www.ebay.co.uk/sch/?_nkw=brake%2 ... 4202155874
Keep the copper grease well away...
Threads: 4
Found a couple of second hand cibie headlights, in the UK not cheap but should do the job nicely. Things are starting to come together at last. Next time I am home it will be door seal time, especially that pesky one near the torsion bar. I have noticed that either one or the other doors hit the T panel when fully up and no amount of adjustment of the panel seems to help. I am slowly coaxing the rear facia into shape and the sag is not as evident.
Threads: 4
Threads: 4
Found this running around the engine bay ? Took a picture next to a Penn for size comparison, it has a small rubber bung in the end.
Finally got the headlights and park lights sorted after spending hours chasing a bad connection to the parker circuit and only getting 2.5 volts to it.
Slowly its getting there and the more I do the more things I find missing or in need of some sort of repair.
Threads: 812
It's a 'bung' that goes in the top adjuster hole of this: Goes where part number 25 would
[ATTACHMENT NOT FOUND]
Quote:and the more I do the more things I find missing or in need of some sort of repair
Just the way it is with these things, lol
Threads: 4
Thanks Chris, I you are a Delorean encyclopedia.
Threads: 812
Quote:you are a Delorean encyclopedia.
err no, just know a bit about something's and odd bits about a lot of things. There are far better Delorean experts out there!
Dunno where you got that image Chris! Item 26. Goes in place of item 25
Threads: 812
? cant even see a 26, but I stand by what I wrote, goes in the hole where 25 was unless I'm wrong? Happy to be corrected if I'm wrong.
Look more closely - the two images are different
Threads: 812
Yeh, I see it shows the plug on yours as item 28, still cant see a 26 though!
Threads: 4
It has been a while since my last post. Time flys when your havind fun!. I have now purchased nearly everything that I need to sort the car out.
New fuel lines,fuse box,relays,pedal rubbers,door seals,roof lining,headlights,tail lights, number plate surround,window switches,headlight switch,washer motor,air filter housing,coill cover,seatbelts and much more.
I just need the time to put it all together now.
Hi David,
does this mean you are going down the standard USA rear light/ number plate surround route? ( like I did)
