Threads: 813
Fuse 18, really good info for you:
http://dmctalk.org/showthread.php?40-Al ... Schematics
would be worth checking for power to the switch at the pedal if the fuse is OK as this sometimes fails as well.
Threads: 813
Quote:called the AA
Ahh yes very nice men 8)
Glad you got it sorted. Cant remember what there from probably best just to get one from Ed.
http://www.delorean.eu
http://www.delorean.eu/catalog/product_ ... _id=102003
Threads: 813
Ahh, yes sorry put the wrong one up :roll: Ed will post one quickly to you only takes a couple of days to get hear.
Threads: 9
I recommend LED fuses, they light up when they blow (as long as there is some load on the circuit), so it's easy to see what to replace looking at the fusebox. John Hervey does a full set for the DMC-12.
Threads: 813
Hear you go about 3/4 way down the page:
http://www.specialtauto.com/delorean-pa ... rical.html
This is a really useful A4 sheet to print of and keep in your car as well:
With thanks to Johnathan from DMC talk
[ATTACHMENT NOT FOUND]
