Threads: 79
I think I'm going to put new outer door seals on my car and wondered which ones are recommended as being good.
Ed's seem a good price, as do John Hervey's, Martin's Silicon ones are the most expensive but are they really worth it?
Threads: 84
Hi Dan,
I used the DMC ones like Ed's. No Problems at all. In theory Martins should be best, but whoevers you use the final finish is down to the fitting.
There's a few useful tips on the forum already so I won't go over old ground. I'd read them through and take your time fitting them to get it right.
D
PS, put the Scuffmaster in the post to you today, PM me if you need any help/advice on applying it.
Threads: 79
Cheers Darren, I might get Ed to bring a set to eurotec then. If they are good enough for you they must be ok :wink:
Thanks for the scuffmaster. I'm assuming I can brush it on to get an even coating?
I have a set on that PJGrady supplied me ... still look great 2 years on .. they do a small and large profile depending upon your door fit...
Threads: 84
Hi Dan,
Your better putting it on with a sponge (honest) you can use a small one like a pan scrubber type (just dont use the scotchbrite side :wink: ) then you wont get brush marks.
For the flat surface a sponge mini paint roller will do a good even job.
The best advice is do it in thin coats not one thick one, and allow it to dry in between.
D
Threads: 79
Thanks Darren I'll give it a go later this week.
Thanks Mike I'll check out their site.
