What parts do I need to modernise?
The cars will be here in 6 weeks and I need to start pricing up replacement of parts and where to get them. I also need help with what is involved in a stage 2 engine. I have seen them discussed but nothing in detail. I hope to work on the engine while the frame is away so would like the parts to be here.
VIN 2456, 2835
DOC 621
a stage 2 is basically a volvo set up ie venturi metering head cpr dizzy i have just done mine and it was only by chance i found a c plate estate, i got all the bits. They are getting rarer by the day so good luck TT
Tourettes Tony Wrote:a stage 2 is basically a volvo set up ie venturi metering head cpr dizzy i have just done mine and it was only by chance i found a c plate estate, i got all the bits. They are getting rarer by the day so good luck TT
No worries it was more curiosity than anything else. I'll get the basics sorted first to have the engine bay sparkling. Hopefully sorting a website out to document my work as I go.
VIN 2456, 2835
DOC 621
well part of the reason why i was after the kit is i have a single turbo set up. i should get a few more hp with the richer mixture, and there is no lamda to worry about TT
Also being more efficient it should do slightly better mpg I would imagine?
