02 Apr 2009, 21:10
		Hi Guy's
Following my request for a special Delorean tool for the diff seal carrier and bearing adjustment, it seems no one has one?
You all know me by now, and the fact I have a slight play in the drive shaft bearings of vin 4532, it wouldn't be long until everything was put right :lol:
I've spent the last few evenings and early mornings (watching the sun rise) making a special tool as shown in the DMC workshop manual.
First I tool some 4mm plate and roughed out the "gear wheel shape"
![[Image: 100_0574.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0574.jpg)
Then I finished it off on my lathe.
![[Image: 100_0576.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0576.jpg)
Next I took some 2" heavy gauge mild pipe, cut it to length and drilled it out 16mm on my pillar drill.
![[Image: 100_0575.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0575.jpg)
And finally welded it on to the top of the gear wheel with my MIG.
![[Image: 100_0577.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0577.jpg)
This should locate in the seal carrier ring once the drive shaft flange is removed. Using a standard 1/2" drive Tommy bar through the 16mm holes I should be able to easily remove the ring, take a look at the bearings, put in a new seal and then tighten it up to remove any play. :lol: :lol: :lol:
I'll post some more pics over the weekend showing how to use the tool.
Kind regards
D
Kind regards
D
 I think you have the same welder as me too.  :wink:
![[Image: 100_0580.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0580.jpg)
![[Image: 100_0581.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0581.jpg)
![[Image: 100_0579.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0579.jpg)
![[Image: 100_0582.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0582.jpg)
![[Image: 100_0584.jpg]](http://i265.photobucket.com/albums/ii221/DarrenLCollins/100_0584.jpg)
