04 Mar 2009, 15:05
Dan1986 Wrote:So the earlier dmc ones were actually longer than the original!! :roll:
Yeah only by a few mm, but it meant to get a good seal you had to take the fuel tank coverplate off from under the car, install the sender and then screw the cover plate back on, this allowed you to make use of the flex in the tank to accomodate the extra few mm. not ideal.
I understand the new sender has been updated in both its overall length and it now has around 12 level incroments which makes for a much more accurate reading.
James
www.classicdelorean.com
Colchester - Essex - UK
