15 Aug 2007, 18:53
this has pissed me off.
our oven has gone up the creak, so i decide to look for an energy efficient one that connects via 13 pin standard plug (wall socket deal).
I select the electrolux EOB53000 as a suitable replacement. lovely it all seems. I sent an e-mail to electrolux to confirm whether or not this unit would run on a standard mains circuit and not need a cooker circuit as most ovens do these days.
my request for info:
''Hello.You specs sheet says that this appliance runs on 13amps.Can this oven be installed and connected to the mains using a standard plug and socket equipped with a standard 13 amp fuse? Or does it need to be hard wired to a dedicated cooker circuit?The 13 amp makes me think that this can be plugged in, like our existing oven, but the specs sheet is not that explicit.cheers!Dave''
their response:
''Thank you for your correspondence
This cooker comes with a standard 13amp plug that plugs into a wall socket.
Kind regards
Electrolux Consumer Care Team''
all would seem fine. except today when the thing arrives with no flex or 13 amp plug and an instruction booklet which says:
"Connection via: cooker control circuit
min cable/flex size: 2,5mm2
cable flex: PVC/PVC twin and earth
fuse: min 15A / max 20A
It is necessary that you install a double pole switch between the oven and the electricity supply (mains), with a minimum of 3mm between the switch contacts and of a type suitable for the required load in compliance for the current regulations"
this seems like direct contradiction to the advice electrolux themselves gave me before i bought the thing.
Advice. I'm pretty sure that i won't be able to get away with sticking a flex and 13A plug/fuse on the thing and let rip.
i will have to get a cooker control circuit (wiring point and switch, wire and breaker), won't i?
the amperage on the current oven/main house sockets breaker at the moment is 32A
ho hum.
Dave.[/b]
their response:
Kind regards
ho hum.
Dave.[/b]
