26 Mar 2019, 18:19
So my right indicator on the cluster is not working.
When I indicate right, the front and rear indicators outside work as normal.
But the cluster doesn’t show that it’s indicating right.
Left works perfectly fine.
Hazards only illuminate the left on the cluster, but outside all is fine.
Additionally, I can hear the indicator clicking when indicating.
This happened to me a few weeks back, and then it started working again.
And then today on the way home it stopped again.
Loose connection on the cluster perhaps?
The low beam indicator is quite dim.... so perhaps a contact issue perhaps.
And the connection on the circuit board is not working for the temp gauge as I had to run a new wire to get that working last year.
So perhaps I need a new circuit board?
If so, is that easy to do?? I don’t fancy getting the binnacle out
(Which I know I’d need to do....)
