26 Mar 2018, 22:17
Another new recent problem, my fuel gauge is pointing down no matter what.
So far I've done the following:-
I've used the multi-meter to verify that the signal from the green/black wire (for the gauge needle) beeps at the plug for the sender as it does on corresponding pin (A4) on the big white connector behind the binnacle. I then kept the multi-meter on the same sender end of the harness and tested each other pin of the binnacle connector expecting to hear another beep from another wire to indicate a short, but there were no other beeps.
I then performed the same test for the light green and orange wire (for the sender light) in the same way to the above, only to find the same outcome.
I'm pleased that there appears to be no short but stumped as to why my gauge is all of a sudden pointing south. The other gauges are all still running perfectly.
Any input or suggestions would be most welcome.
Thanks in advance
Thanks in advance
