Grrrrr. Another day at it.
As most of you know, I use my DeLorean as a daily driver, so it has to be in GWO. Pfff, Tsssk Tut ! Yeah right!
I got to work today only to find transmission fluid had poored all over the road. Luckily there wasnt too much wasted, and I had enough to get me home (only 1 mile away). I had over filled the gearbox anyway.
I got home and decided to yet again strip the whole thing apart again. But seeing as I was late out of work, I didnt have much natural daylight left, so I had to get a move on.
I started by emptying the Auto trans sump, then removing the sump itself, only to find my gasket was totally shot, hence the aweful mess.
I took this opertunity to remove the solenoid valves once again.
I have circled where they have been removed from.
Larger Image
http://www.aqzj73.dsl.pipex.com/solenoids/10.jpg
I decided to take the oversized O-Rings off the solenoid valves, as I was getting some strange gear changing! And replace the originals.
Larger Image
http://www.aqzj73.dsl.pipex.com/solenoids/11.jpg
Knowing that there could be a problem with one of these things, I decided to "Blow" in one end of the solenoid valve to see what would happen.
Apart from getting a gob full of DextronIII, I found air passed straight through the solenoid, until I lightly touched the copper ball at the back. Thats when it performed like a valve, and stopped me blowing through it.
Larger Image
http://www.aqzj73.dsl.pipex.com/solenoids/12.jpg
I did the same with the other one, and found it was blocked. So I attached a piece of hose to the o-ring side of the solenoid, and filled the pipe with WD40. I proceeded to blow down the pipe whilst intermittently tapping the copper ball at the back. Eventually it seemed to free up some what. Now.... I was hoping this would work. So I put them back into place.
Larger Image
http://www.aqzj73.dsl.pipex.com/solenoids/13.jpg
It was then, I realised, my gasket !!!!
Damn, id have to improvise.
I had a tube of orange instant gasket which I thought would work by itself. I put an adequate amount of sealant around the sump lid and fastened the whole unit back up. I gave the sealant a few minutes to cure then began to top the tranmission back up with DIII.
Done at last...................until............I see all the fluid Ive just put in, running past my feet !!!! Arrrrrgh.
Drain, and remove AGAIN!
By this time its nearly 11PM!
I needed a solution FAST. I took a tip from someone I know, and decided to have a go at making a temporary gasket from a cardboard box!
I spent plenty of time on it, and made sure everything was as close to the original gasket size, as possible.
Upon finishing the cutout, I coated both sides of the cardboard with silicone sealant.
Larger Image
http://www.aqzj73.dsl.pipex.com/solenoids/14.jpg
Then with my finger, made sure it was evenly spread.
I put it all back together again, and..............................it still leaked !!!!!! GRRRRRRRRRRRRRR
DONT TRY THIS AT HOME !!!! :lol:
Larger Image
http://www.aqzj73.dsl.pipex.com/solenoids/15.jpg
It always goes wrong when you need your car the most!
I have a payed hire to attend on Sunday. I've sold my business, and start my new job in Sheffield City Center on Monday. Typical! LOL
Anyway, I put my car back on my drive with loads of cardboard down and a sink bowl under the sump.
Looks like Im walking to work tomorrow !
Lend me your D Nick
LESSON FOR TODAY.... There's right tools and right parts for the right job. Dont skimp!
Dont suppose you have any pan gaskets do you Dan?
