15 Dec 2011, 13:00
Pages: 1 2
15 Dec 2011, 14:06
Is it pouring out under force?
There are no oil lines in that area.
Could a hole have opened in the valley?
15 Dec 2011, 23:06
Needs more investigation I'm afraid, could be a number of places: timing cover gaskets/oil seal/rocker cover gaskets... however having had a hole in the valley myself I can confirm that it does come out at a fair rate and does a good job of covering the cars windscreens behind you when your driving along Really difficult to trace as well as you need the engine running to find it but you cant see in there with all the intake Etc on. even with a borescope could not see it.
16 Dec 2011, 05:03
VBP355 Wrote:OIL RUNS OR POURS OUT FROM UNDER WATERPUMP; UNDER INTAKE ;RUNS DOWN FRONT OF ENGINE. IS THERE A OIL LINE THERE???OIL RUNS OUT LIKE POURING OUT OF NEW CONTAINER. PUMPS OIL OUT OF ENGINE IN ABOUT TWO MINUTES....WILL HAVE INTAKE OFF TOMORROW.....
16 Dec 2011, 11:39
Doesnt sound good then.
Have a look at http://www.delorean.ie/forum/viewtopic.php?f=5&t=1936
Shane didnt find a hole but it shows you the corrosion that can occur.
16 Dec 2011, 21:57
That does not sound good I tried allsortss to fix it from stuffing chemical metal down the holes to having all the top of the block TIG welded to seal everything up. The oill just kept finding another hole to come out of. Changed the block in the end.
18 Dec 2011, 13:25
Don't run the engine without oil! It'll take only seconds to to permanent damage.
It does sound like the block has corroded through, or if you're lucky, it'll be the steel plug which is immediately behind/under the water pump (the one with the hexagonal key)
18 Dec 2011, 14:55
stunned_monkey Wrote:Don't run the engine without oil! It'll take only seconds to to permanent damage.OIL COMING FROM BLOCK .DEEP CASTING IN MID VALLEY. CAN ALUMINUM BLOCK BE WELDED?????
18 Dec 2011, 17:45
Yes, but it's not easy, it's a pretty poor quality casting.
18 Dec 2011, 22:15
Quote:OIL COMING FROM BLOCK .DEEP CASTING IN MID VALLEY. CAN ALUMINUM BLOCK BE WELDED?????Can be, BUT I tried it it did not work, had it all professionally welded up but it just kept finding the next weakest spot to come out of. Really are better trying to get hold of a replacement block.
19 Dec 2011, 15:15
Sounds nasty - and I have to add weight to the argument that it's very dicfficult to succesfully weld a cast structure, you'd be exceptionally lucky if it was succesful - I think it sounds like you're in the market for a new motor unfortunately :-(
21 Dec 2011, 03:34
Rich Hanlon Wrote:Sounds nasty - and I have to add weight to the argument that it's very dicfficult to succesfully weld a cast structure, you'd be exceptionally lucky if it was succesful - I think it sounds like you're in the market for a new motor unfortunately :-(BLOCK IS LEAKING.... DOES ANYONE KNOW IF AN EAGLE 3.0 ENGINE BLOCK HAS SAME MOUTING & BOLT PATTERNS AS DELOREAN 2.8
28 Dec 2011, 17:28
Eagle 3 litre is just a Renault 3 litre common to Safrane and Laguna. Everything except DeLorean pistons will bolt right in.
21 Jan 2012, 14:23
VBP355 Wrote:OIL RUNS OR POURS OUT FROM UNDER WATERPUMP; UNDER INTAKE ;RUNS DOWN FRONT OF ENGINE. IS THERE A OIL LINE THERE???found hole in block. i have repaired hole,no more leaking.
21 Jan 2012, 20:38
How did you repair it in the end? Any pics?
Pages: 1 2
