Quote: Re: OIL LEAK
VBP355 wrote:
OIL RUNS OR POURS OUT FROM UNDER WATERPUMP; UNDER INTAKE ;RUNS DOWN FRONT OF ENGINE. IS THERE A OIL LINE THERE???
found hole in block. i have repaired hole,no more leaking.
Could you post up details and pics of what you did and wher the leak was? getting a common problem this so may help people out a bit.
will try to put some pictures on in a few days.
I have did the best i can ,have more photos,cant put them on ,onny 3. Hole in block, patch with JBWELD,AFTER CLEANING,small dab,let cure,then 1/2'' JBWELD, let cure, fill with RVT,cap with gasket material. u might can see small piece of angle metal under cap. 4 pieces bolted & JBWELD toblock web, drill & tap 4 pieces to dolt cap to.
I tried to put pictures on site,did not work.
