Is it possible to use a rear demister switch in one of the normally blank spaces as a fog light switch? or something similar? I want to put the fog light switch in that area and it would be good if I could do something that matches with the existing switches.
Also could somebody run through how to modify the tail lamp boards for fog lights?
Not that this helps you but I started a 'How to' on this .. need to finish it off and put it up somewhere ...
Thanks guys, could anyone do a quick run through of this for me? Just not sure what modifications are required on the light boards.
DMC Houston sell a switch which is the same as a demister switch but with no decal on it. Then you can get a foglight decal to go on the blank switch.
ah right, sounds good ill have a look on their website. I have found a fog light guide on the main club website in the tech section, didnt know that was there so I can wire those up now.
Phil
If you get stuck, always PM RichH (DOC-UK Technical Advisor) - he's done quite a few
of these recently for people, and has also redone one that had been bodged by someone
on another club member's car.
i have used one reversing lamp for mine. (red bulb)
an easy job, and no cutting tail light pcb.
decals from 'vehicle wiring products'
steve
