Hi everyone. What is suposed to be under the T panel? Looking on the parts diagram there should be a roof insulation pannel, is this suposed to be fixed to the inside of the T panel or glued onto the steel roof structure? Also does anyone know what material this is made from?
Thanks, Dan
Hi Dan,
Part Number:106722 INSULATION, ROOF PANEL Price: $38.18
New Old Stock Part
I take it your asking about this stuff glued under the stainless T roof?
As far as I can remember its the same as the sound proofing that sits under the rear carpet on the centre tunnel above the gearbox, between the two wooden access covers.
For £19 ($38) it aint worth trying to match it up to something similar, it'll cost you that in fuel and effort driving around searching!
Best Regards
Dont know how the cool icon ended up in the $38...must be 8 followed by close bracket?
Darren C Wrote:Dont know how the cool icon ended up in the $38...must be 8 followed by close bracket?
You are right Darren.
An 8
followed by a )
makes the cool sunglasses Icon
8) 8 )
: D
etc.
I take it you're gone in search of the fizzing connector then Dan?!
Yes thats right Rich. All sorted now, but I noticed the T pannel had nothing on it, and the insulation was stuck to the actual steel roof area looking sorry for itself, so I might rip it all off and put it back new, but need to know if its supposed to be stuck to the T pannel or the steel part, as I've seen pictures on the net of T pannels with what looks like insulation stuck on so thought mine might be done wrong.
Hi Dan,
Mine was stuck to the stainless T panel.
There's also one on ebay at the moment stuck to T panel too.
Best Regards
Cheers Darren. Looks like mines been done wrong then as I suspected. I'll rip it all off, clean it up and fit a new piece then
