Just 50 or so miles shy of the 30k mark my Lambda light came on. My car no longer has any emissions setup, but obviously the lambda counter doesn't know that.
I haven't had a chance to check it yet, but how do you reset or switch of the light?
If the light is bugging you, just unplug the connector attatched to it. I did that, and reset the counter when I had more time. Its only 2 or four screws from memory, and 2 cable collars to undo.......
Then a small pair of nail scissors should reset it if you have not got the proper tool in a screwdriver bit set.....
May not be a good idea to move the car with the counter out, as this may make the cables difficult to get back in, but I'm no expert....
You've probably learned this already!
Ben
I forgot to post here that I reset the Lambda and all is now well... Easy 5 minute job!
