11 Sep 2023, 17:43
So..
Drove from High Wycombe to Shropshire this weekend and had a breakdown as I was passing through Birmingham.
Clearly, rule 1 is 'don't drive through Birmingham on the hottest day of the year at five o'clock on a Friday afternoon'..!!
However, this was my first breakdown in the car.
As I was nearly through Birmingham (frustratingly), first I heard dodgy whirring noises, then coming off a roundabout she suddenly completely died after some horrendous electricalish whirring noises.
Pretty sure this was the fuel pump having a mad five minutes.
For at least five minutes, turning the key did nothing at all.
After a few more minutes, turning the key turned over the engine (with horrendous noises) but it wouldn't fire.
After a few more minutes, she started but conked out again after going ten yards.
After another ten minutes or so (maybe 25-30 minutes all told?), during which I was on to my breakdown company, she decided to start and I completed the last 30-ish miles and hour of my journey.
So. Questions/advice please!
i/ What was going on? Is this the same as or related to the infamous 'hot start' problem I think I've heard of? Is it usual for this to also result in a breakdown? Was it (theorising here) to do with excess heat causing fuel in fuel pipes to vapourise and 'vapour lock'?
ii/ whatever the problem, does anyone have a solution? should I change my fuel pump? Any other upgrades/ mods I can do?
Further problem: On the plus side, I had my air con looked at a month or so ago and it now works. On the downside, when it's hot, the increased load of putting on the air con and the associated fans pushes the running temperature of the engine up! So when it's really hot, I ironically have to turn off the air con so as to keep the engine cool!!
so, iii/ anyone else had this problem, and did anyone find a radiator / fan / other solution that helps keep all this under control?
My biggest paranoia about running any old car is always to do with overheating.
iv/ Finally, perhaps it's just my imagination, but it seems to me that the warmer the car is, the worse the gearchange gets. Anyone else have this?
It's been a while, hope everyone's well and sorry for just bringing problems to the party..!! :-D
Ivanhoe (80sThrowBack...)
