That was pretty painless compared to some of my other interactions with the DVLA
Just need some insurance now and bolt those few items back on that fell off
Well after a little investigation into my very poor operating handbrake the answer was obvious
Is this a standard failure or what
completly missing including the bolt so im guessing deliberate.
That’s not good at all. The problem you now have there is trying to find a replacement. I’d consider that piece has been robbed rather than fallen off. Unfortunately, the handbrake part of the rear callipers are extremely difficult to source. You may have to get in touch with Houston and see what they have squirrelled away secretly for just such ocassions.
let me have a look first...I may be able to help.
Hi Guy's
Thank you Chris for the offer and I thought the same Rissy but it turns out Delorean Go had them in stock so all sorted or it will be when I get them resealed painted and fitted on.
I also ordered new pads as well but these are square not slopping like the drivers side is, Im sure I spotted a post on here regarding the angled pad
Cheers Mich
That was real luck that Arran had just the one you needed! Excellent! That could have been a proper headache otherwise.
You can buy the pads, new, which come chamfered to shape already, even from Ebay, otherwise you can use your other one as template to file down the new one you have there to be close to what's needed, and then a few gentle pulls of the handbrake at slow speed on a private road will finish it off for you. I did the latter before the pre-chamfered ones appeared on the market and I've had a great working hand brake on both sides for years now. I did experiment with other solutions probably around 2010-2011 for the hand brake to bring about a proper mating of the pads to the disc at the required angle with unchamfered pads when I was having a terrible time with handbrake performance and a continuingly troublesome MOT inspector, but I'm not going to dig up that old chestnut again (in case that's the thread you're referring to).
Glad you are all sorted Mich..
.I have quite a few brake bits if anyone needs anything. Just got my hands all oily for nothing !!!
(13 Apr 2022, 08:47)Chris P Wrote: [ -> ]Glad you are all sorted Mich.. .I have quite a few brake bits if anyone needs anything. Just got my hands all oily for nothing !!!
Do you happen to have any of the box arms for the hand brake mechanisms? Mine have always been broken and held together with cable ties! (Go on, get yer hands dirty again :
Here are my bits....the 'box' levers were seriously damaged by a Plater...they should have been stripped down completely first, as they contain delicate bits. I'm sure they could be repaired ..but there you go..
attachment=1315]
Yeah, that's the bits. In what way were they damaged? Perhaps we should take up this conversation privately rather than hijack Mich's thread....? Sorry Mich.
Hi Guy's and Gals
Finally getting ready to drop the car to the floor sorted the handbrake system seems to work really well now I used a slightly different method of getting the angle on the pad's, I cut two circles of 80 grit glass paper and used some double sided tape to stick them to the discs then rotated the discs and adjusted the large bolt up until they started to sand the pads to shape 5 minutes later boom perfectly matched pads
So all rear brakes are back on cleaned resealed serviced and refitted undertray's removed cleaned out replaced.
Bumper going back on tomorrow
any advice on that aligning it up as it was miles away when I got the car I'm guessing there is some shrinkage in the rubber over the years.
And last question how the heck do you wash it and clean the steelwork afterwards
It looks lovely and clean under there....youve certainly picked a tidy car.
Looking good Mich.
Ref cleaning, a wash with either washing up liquid or car shampoo is fine, give it a good
leather down afterwards.
You can use stuff like Shiny Sinks, Bar Keepers Friend, etc, which are good at a deep clean of the
stainless. I've tried various stainless cleaners over the years, some are better then others, some
leave the metal looking quite dull or streaked.
(03 May 2022, 22:28)Mich1958 Wrote: [ -> ]Hi Guy's and Gals
Bumper going back on tomorrow any advice on that aligning it up as it was miles away when I got the car I'm guessing there is some shrinkage in the rubber over the years.
Damn that's one clean underside
putting me to shame on cleanliness of my underside (that's what i get for not having a lift
i still got to fit my rear fascia but still got other bits left like sorting my now dead oil pressure gauge
, axle boots and other odd ends
in regards to cleaning ive used WD40 for 3 of my panels that had paint on and they came up as nice as you expect from a scuffed up door and rear panel haha
