10 Aug 2016, 12:05
Hi all.
After neglecting my D a little in the last 3 years, I decided I want to re-live the dream once again.
To car was last tested in October 2013, driven back to my unit, and not turned a wheel since.
However, you may remember I renewed all the fuel tank pickup, return pipe, question mark hose etc shortly after laying it up, so the car has also not had fuel in it until last weekend.
I brought the battery home to charge, and being a 2004 battery, it was well past it's sell by date, and almost split out of the casing... it would not charge at all, and 4-5 volts was the only output I could get.
I also had another battery, which was the smaller Numax some of you have been buying, but I wasn't happy putting that back on either.... that was bought in 2008, and I realised then just how fast the last 8 years have gone.... frightening!
I made a discovery on the Tanya batteries website, and managed to get as close to an 096 as possible, but with side terminals and a 4 year warranty.
Here are some pictures...
![[Image: IMAG0082_zpslrqdr0sa.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/IMAG0082_zpslrqdr0sa.jpg)
![[Image: IMAG0083_zpsw7rzbsxk.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/IMAG0083_zpsw7rzbsxk.jpg)
![[Image: IMAG0084_zpserbwmac1.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/IMAG0084_zpserbwmac1.jpg)
![[Image: IMAG0087_zpsxgriyefl.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/IMAG0087_zpsxgriyefl.jpg)
This is my old battery, and you can see how it's swollen from storage. The amperage and CCA figures are slightly higher on the old one, but this is as close as I can get, that will fit in the tray.
![[Image: IMAG0086_zps9v58hidl.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/IMAG0086_zps9v58hidl.jpg)
![[Image: IMAG0085_zpsny1khab5.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/IMAG0085_zpsny1khab5.jpg)
This is the other old battery, the same as I've noticed a lot of you buying.... however bigger and better is available with side terminals....
![[Image: 75-60_zpswiqvbac4.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/75-60_zpswiqvbac4.jpg)
https://www.tayna.co.uk/75-60-Numax-Side...P3141.html
Yes it's cheap, but it's not really man enough, and it only has a years warranty...
Get this....
![[Image: 75-60_Enduroline_zpsmgxmw9az.jpg]](http://i1320.photobucket.com/albums/u525/theoriginalmrp/75-60_Enduroline_zpsmgxmw9az.jpg)
https://www.tayna.co.uk/75-70-Enduroline...P8472.html
Anyway, after nearly 3 years, a fuel tank components refurbish, and about 2 minutes of short burst cranking, she started... runs perfectly.
And it becomes apparent a new battery is good for these cars, because all the lazy components, IE central door locks, odd bulbs, starter/solenoid etc all work straight away first time.
I've now gotta run it around the industrial estate a few times to get to trust it again, and loosen everything up....
I will take it for a test in a few weeks all being well!
As I can't edit my last post, I will just note this battery has a handy carrying handle, a charge indicator, and is delivered in less than 48 hours. It comes extremely well packaged.
Get this....
