18 Jun 2014, 21:03
How about we create a new section of the forum that has a nice simple all in one check list of items needed for servicing the car and crucially the part numbers?
I'll start with what I know in regard to the items that need checking/replacing but sure there must me more parts/items I've not covered:-
Servicing
Oil 10/40 semi synthetic – 6000 miles/annually Volume needed from empty ?
Oil Filter
brake fluid – change every two years?
Grease nipples on control arms for ball joints upper and lower
Dist Cap (every 12,000 miles?)
Rotor Arm (every 12,000 miles?)
Air filter
coolant – 50% mix? Which type/does it matter
clutch fluid (dot4 only) volume from empty required ?
spark plugs
fuel filter
brake pads – greenstuff
Belts
aircon belt
altnerator belt
aircon
R134a gas (amount required 950g?) Oil amount?
Orifice tube
Accumulator
check for play in balljoints
The above lacks the current part numbers. I know some of those previously published are no longer correct/current so any help with publishing those that are known to be current/correct would be great.
Servicing
Oil Filter
Air filter
spark plugs
fuel filter
Belts
aircon belt
altnerator belt
aircon
Orifice tube
Accumulator
