Full Version: Stainless Steel Sun Visor Nut Plates
These are made to order, so it may take a day or two before I can post out.
These are a direct replacement for the mild steel items.
Rivet holes are drilled at 4.1mm allowing you to oversize if required to 4.8mm.
£17.00 for a set of 4 nut plates including 1st class post.
[Image: 20140119_194056869_iOS.jpg]
Got my set, thank you! My old ones compared to the new ones Shock
[ATTACHMENT NOT FOUND]
