With just over a day to run on eBay, this rare PRV v6 engined 604 deserves a good home otherwise it goes to the Destruction Derby. It's got to be worth saving as its going to go very cheap! 8)
Can you link to the auction?
stunned_monkey Wrote:Can you link to the auction?
It's this one. I asked Chris N if he wanted it, said he had enough PRVs needing rebuilds as it is.
there's a T reg one of these that does the car shows round Hertfordshire -
Yes I'm sure I have seen that one as well, IIRC it's got a huge round air filter above the air inlet intake!
thats the one
It went for £335, hope it went to a good home! 8)
It's only really of interest to us for the engine, and being a 2.7 even that's only limited. I suspect it's too old to have K-Jet which means there really isn't much of use. I wonder if it has the same lower crank case....
2.7 with a carb in the P604 - hope you're right Brian, and the car has been saved.
