Anyone know what this plug is under the NSR wheel arch? Mine was unplugged and has been for some time, but have now plugged it back, but suspect it's now part of a removed circuit from some time ago now...so don't expect it to be doing anything even when plugged back.
Looks like the Lambda lead going to the ECU behind drivers side
Did you get home all OK???
Wire goes IIRC to the oxygen/lambda sensor in the exhaust if it still exist's. MG will know more on that I'm sure.
Ok, well if that's what it is, then this would explain it not being connected. LEX has been stripped of everything related to monitoring her affects on the environment. lol!
Yeah, I got home fine thanks Chris. LEX was good as gold after Sunday morning's hiccup. So I wont be needing an AA membership from you JUST YET. :wink:
[quoteYeah, I got home fine thanks Chris. LEX was good as gold][/quote]
that's great, was all I wanted to know as we had not seen anything of you in the last few days!
Yeah, just been really busy since I got back to Edinburgh. Had a friend visiting from Australia the last few days, and then taking the remaining opportunity to make use of the TAX on LEX to drive her about Edinburgh and do some more handbrake adjusting etc ready for MOT time in September. The SORN process for her is now underway again.
Booooo!
I think I may have finally cracked my handbrake issue. Time will tell at the MOT in September, but yesterday it felt much more positive and managed to hold the car quite still on some quite impressively steep hills too. So fingers crossed! :lol:
