23 Apr 2013, 20:31
24 Apr 2013, 16:47
Oil:
Most of use will use either 10w/40 or 20w/50, the choice is yours.
Oil Filter:
Mahle OC460
http://www.ebay.co.uk/itm/Genuine-Mahle ... 257cb3abae
Air Filter
Mahle LX689 - http://www.opieoils.co.uk/p-61769-mahle ... fiat-.aspx
Or a Bosch filter should be readily available from your local euro car parts store if you prefer: http://www.eurocarparts.com/ecp/c/Fiat_ ... 7cd&000008
Fuel Filter:
Bosch 0 450 905 401
http://www.ebay.co.uk/itm/1x-Bosch-Fuel ... 4abc825af9
Plugs:
Bosch HR6DC+ http://www.ebay.co.uk/itm/6x-Bosch-Supe ... 35bc65523a
Distributer Cap:
Intermotor 44030
http://www.ebay.co.uk/itm/INTERMOTOR-44 ... 257d1ccf5d
Rotor Arm:
Intermotor 47080s
http://www.ebay.co.uk/itm/1x-Intermotor ... 2ec2d7dad4
Oil Filter:
Mahle OC460
Air Filter
Fuel Filter:
Bosch 0 450 905 401
Plugs:
Distributer Cap:
Intermotor 44030
Rotor Arm:
Intermotor 47080s
24 Apr 2013, 17:42
its a piece of p*** to service one of these, even I can do it!
24 Apr 2013, 20:58
Quote:Fuel Filter:Also from same seller Bosch Oil Filter: http://www.ebay.co.uk/itm/221130835520? ... 124wt_1328
Bosch 0 450 905 401
24 Apr 2013, 21:17
FWIW from what I've read online, Bosch oil filters aren't all that hot. Personally I'd stick with the Mahle filter if at all possible.
24 Apr 2013, 21:23
Quote:FWIW from what I've read online, Bosch oil filters aren't all that hot. Personally I'd stick with the Mahle filter if at all possibleYes I had read the same, but these are made in Germany, not Mexico as the US ones and the same as Ed sells, so should be OK (one would hope :lol: )
However with a Mahle at £6.69 delivered you cant go wrong really!
