so more entertainment than anything (oh and me finding out what bits are what!) can anyone tell me what is what out of these random bits?
i will put a prize up of a kit kat, 4 fingers, not a chunky, just 4 fingers.
Numbered left to right from top.
1 Cover plate for boot lid catch
2 Rubbers strips lh & RH top of quarter panels for louvre cover to sit on
3 Looks like bonnet catch less support bracket
4 Header tank support bracket
6 Bonnet catch cover
7 Brace front centre behind front facia on centre line of car
8 Water hose.
12 trim side strip rear quarter by side marker
11 Trim side strip LH front fender (between wheel & door)
ha top job, number 2 the 2 strips are actually metal, cheers for that info tho helps great deal!
Hard to see in your pics they looked like rubber.
In which case they are the steel clip strips that hold the mesh in the openings of the lower engine lid.
Have you got a picture of 9 & 10 from the other side?
Ahhhh, you crafty so & so
No 9 is the bracket that supports the glovebox striker catch, but it still has a part of the broken striker plate screwed on to it.
I knew I'd seen it before, but it didnt look right.
ahh, i thought 9 was that, it has a vw part number on the left side bit of it so that confused me
number 10 has a circular centre like it clasps a bar or pipe
i will grab another picture tomorrow when back at work
you done good tho! pm me your address for the kit kat!
Ah Ha
10 is the oil cooler clamp, the threaded holes with the screws left in gave it away.
:lol:
Can I change my mind on No 7
I think its the bracket on under the lefthand side of the dash, that braces the small lower section holding your interior light switches. (its too short on one end to be the facia support that I first thought it was).
1. 106777 Access Panel inc 106778 Gasket
2. x2 off either 106388 - 106392 Ret Strip
3. 101574 Lock and Latch
4. 105779 Bracket
5. Random Pipe Elbow - Non DMC
6. 106944 Latch Cover
7. 105283 Bracket LH
8. Damn I'm sure I've seen that before....I'm thinking transmission
9. 107557 & 107558
10. 106151 Oil Cooler Clamp (also clamps coolant hose on manuals)
11. 100644 Rub Strip Rear Quarter RH & 101742 Rub Strip Common End
RichH Wrote:1. 106777 Access Panel inc 106778 Gasket
4. 105779 Bracket
9. 107557 & 107558
L.O.L
LOL Rich,
I thought that was a non DMC hose too, since the bend is too tight. Probably aftermarket that a previous owner fitted.
The race is on for that last bracket, but it may be a red herring as I dont recognise it either?
