30 May 2012, 11:35
30 May 2012, 12:33
Feed TO the radiator is on the Driver's side (TOP of Radiator)
Return FROM the radiator is on the passenger side (BOTTOM of Radiator) + a small air lock outlet at the top of the radiator (in most cases, as i think some have removed them...for whatever reason!?) on the same side which joins the same return line back to the expansion tank etc in the engine bay.
30 May 2012, 14:53
cheers mate, i did assume this but wanted to make sure!
