23 Oct 2011, 21:29
24 Oct 2011, 10:33
if you join www.vodc.co.uk (Vauxhall Opel Driver's Club), who are a really friendly bunch,
I'm sure someone there will know - there's quite a few current and ex Vauxhall Technicians
on the forum who will be able to help.
24 Oct 2011, 14:14
cheers claire i will do that thanks
24 Oct 2011, 18:32
no problemo Steve, hope you get the info you need
24 Oct 2011, 22:57
hi steve if your running an 8 valve corsa they use hydraulic lifters which you are unable to adjust, you can take them apart and clean them or very often an oil change with good quality oil helps (new ones are only about £6 each). My daughter uses one in here race car and when they run hot you get the the ticking but that stops as they cool down , that motor is known to wear the cam after high millage but it only means you loose some power give us a shout if you want to know more brian
