hi trying to fit a replacement fuel pump but unable to connect the banjo as the original is an old style pump. Should my new pump of come with a domed nut. cheers Brian
wow seems alot for a nut i thought theyd be a straight swap perhapes it should be mentioned in the pump discription thanks again will get this car on the road one day
should ther have bean some connectors and covers?
Depends where you bought the pump. Mine come with two eyelets, nuts and boots. From DMC you have to buy their little loom seperately.
i used a specialTauto kit but found the banjo threaded bit too short, and so i think is the oem one.
and fitted all together, can ran for a minute then cut out.
found fuel literally spraying across the top of the tank, and under the car...a very HOT Delorean moment!.
so i hunted down a banjo and connector that cannot come loose
this place
http://www.speedflowshop.co.uk were very good, made me up a high pressure line, banjo etc to guarantee it could not 'blow off' under pressure.
the weaker point then of course is the connection to the old Delorean fuel line (i could not get the return metal/plastic connection apart, however this is under lower pressure i think.)
The whole fuel tank/pump feed system i think is a bit poor, with quite a few owners with fuel smells leakage etc around the top of the pump
[youtube]http://www.youtube.com/watch?v=3vCAG2IUb3E[/youtube]
[youtube]http://www.youtube.com/watch?v=vHN3Cu6TjWs[/youtube]
