DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE
1 - Engine
> Changing main crankshaft oil seal (transmission end!)
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Rich Hanlon
07 Sep 2010, 10:22
Quick question – does anyone know if you have to drain the oil before you change the main crankshaft oil seal? Ie, is the normal oil level above this point?
Ta!
R
Rich Hanlon
08 Sep 2010, 08:54
Just to post this bit for posterity: Oil level is below the seal, i.e. you don't need to drain the oil to change the seal...
Which is of size: I.D. 80mm O.D. 100mm Depth 13mm
1 - Engine
