Full Version: Block coolant drain plugs
Hello
This question refers to a friend's Volvo 262 but they share the same engine Smile
Does anyone know the size of the coolant drain plugs as shown in the pic below? It also looks like a long socket will be required due to the tap end.
looking forward to hearing from you
Shimon
[Image: 262blockcoolantdrainplug.jpg]
Not sure of the size, however on a DeLorean simple blanking plugs were fitted rather than the Volvo ones that you show, Usually there full off crud behind the plugs anyway!!
Thanks for the info. Oh, so how dya drain the block on the Delorean?
S
