Yes, basically if you look at pics 2, 3 and 4 you can see bubbling under the paint - this could be either rust, welding or something else. But I'm sure others here will know more...
Does not look to bad BUT it's well worth trying to get someone to look at it for you. The DMC talk bunch are a great group and there is nearly always someone in the area that could give it a look over and give you an un-biased view. Failing that it would be worth paying someone from one of the DMC service centres if there close enough.
"Well Doc, we can scratch that idea..."
Check this out, posted over at dmctalk yesterday evening!
snyder Wrote:Goggle can be your friend.. It is hard to hide on the web.
Buyer beware.
http://www.justice.gov/usao/vae/Pressrel...weller.pdf
I guess the search continues.
