Does anyone have a spare Track Rod End they want to sell, or know what x-ref part this is and where to get it?
Ayup matey,
I think they are the same as a Triumph Herald if I remember right, you should be able to pick one up from any motor factors.
Phill
Paul,
if you get stuck, I got mine off Ebay really cheap, and it turned out the seller was SOC
in Headcorn, Kent, who used to supply DMUK back in the days......
They were less then a tenner the pair with postage IIRC. Might still have the part number
kicking around somewhere......... I'm sure I kept it for reference......... but if you ring SOC
(they might be called summat else now tho - but Dan Shane will know for deffo), and ask
for DeLorean track rod ends they'll know what you want
Hope this helps mate,
Cheers fella. I have the number off Martin.
As you all know, you have to cut the triumph ones, so that they aren't too long. There is a cross ref out there that are the same size + shape as the originals. They are for early 80's Rovers part number FTR4054.
Stu
Hi, I replaced the track rod ends with a pair off a Austin Metro (1983), off the shelf from any motor factors and £6.99 the pair. May help someone changing the track rod ends in the future! :wink:
Thats a great cross reference. Thanks!
I have took the liberty of adding it to our cross reference section
and crediting you.
