27 May 2009, 21:27
Hi again.
Today I stripped out the glass and cleaned the old glue off. Actually the glass was held in with silicon sealant before which probably explains why it came out so easily and why the seal was all loose and nasty.
Now its all clean I have a question about the little metal tabs that are around the window frame. In the picture below you can see what I mean. Is the glass suposed to press up to these tabs, or tuck in behind them where the red line is?
Another question. I cleaned the goo off my glass and was wondering if the tiger seal would stick ok to bare glass. Normal car windscreens have a black coating around where they glue, do I need to paint somthing on the edge first?
And finnaly one last question!! I tried to get tiger seal today with no luck localy but found this stuff. Is this stuff the same thing or should I wait and get tiger seal?
