10 Oct 2008, 10:49
Hi all,
I was fortunate enough to use my DeLorean to commute to work for a few days last week which was a good opportunity to give a good run around.
I have noticed a few things that I would like to get sorted.
Engine
I think these are probably engine set-up issues rather than anything serious.
1)When starting the car always cranks a few times fires splutters and then stops and then on the second attempt fires right up, this happens weather the engine is cold or hot so I’m assuming it’s some kind of fuel pressure issue.
My fuel pump does not prime when the key is in position 2 but I understand that this is more of car-to-car thing rather than an intentional design of the RPM relay.
Also is there an easy way of testing to see if the cold start valve is working?
2) Under heavy acceleration it feels as if the car is almost pinking, I’ve experienced fuel starvation issues in the past and I’m sure this is an ignition issue. What should the timing be set to for an engine with the so-called “Stage 1 Upgrade” ?
3) Could someone sketch out the best vacuum pipe routing for the stage 1 engine as I’m sure that my vac pipes are all wrong and I wonder if this is causing vac advance issues in which case it may be the answer to my previous question.
Sorry Nick T you did describe it over the phone but that crumpled enveloped that I hurriedly scribbled it down on has since been recycled.
Electrical
The indicators on my car work fine but the tick-tocking sound in the cabin is virtually silent, is there any easy remedy for this?
I often find that the steering wheel (however I adjust it) seems to hide the flashing indicator signals on the binnacle from view and I often forget to cancel them. It almost caused a nasty incident at a mini round-about the other day.
As always any help greatly appreciated.
James
Engine
Electrical
James
